Group: DynoMotion Message: 5052 From: albertplatek Date: 5/24/2012
Subject: KFLOP Motion Control Board
Hi Tom and all KFLOP Users,
I want to share my experiences about motion control boards:
My first cnc machine was china router controlled by external dsp controller
- it was not bad for simple 2D jobs, but on 3D was really slow.
I decided to swap this control with Mach3
- it helped a bit but Mach3 Constant Velocity is not perfect
if you want achieve high speeds with reasonable tolerance it slows down too much, if not it blend corners too much.
And LPT paraller port was also limiting max step frequency and it was sensitive to PC CPU usage.
Third try was USB SMC4D control from Boenigk electronics (software cncGraf)
it was fine control board, but first biggest porblem was curve speed calculation -
sometimes speed on small curves was same like on straight lines (!!!!!)
I was also considering to buy SmoothStepper but it need Mach3 and Constant Velocity mode is not good. ( at least for me)
I lost hope in finding good cnc control board.
But finally I decided to buy KFLOP Motion Control Board (+ KMotionCNC),
It was best choice!
- SUPPORT IS BEST
- KFLOP calculate speeds on curves perfectly + collinear tollerance make motion smoother
- Performance is unbeatable
- Trajectory Planner Corner Rounding - makes motion even more smoother and allow machine with higher speeds on curve shapes.
- Low Pass Smoothing - final smoothing - more speed on complex shapes ! + extend lifetime of your CNC :)
I hope that more people will decide to buy KFLOP it is powerful product + programmability makes it great Motion Controller!
Albert PĀ³atek
Group: DynoMotion Message: 5053 From: Lee Studley Date: 5/24/2012
Subject: Re: KFLOP Motion Control Board
I agree with you on all counts! Kflop and Tom has been great!  -Lee Studley
It was best choice!
- SUPPORT IS BEST
Albert P³atek
Group: DynoMotion Message: 5054 From: Tom Kerekes Date: 5/24/2012
Albert you really made my day.
